Godfather1111
I hope you guys have patience for newbies. I have an 02 GTI LE that 100% froze up from just sitting up. I bought it from a friend of mine back in 2010. At that time, it only had about 20 hours. I maybe put 10 hours on it over the next 8 years. I would start it twice a year until 2020. At that time It may have sat for I believe 2 years. I tried to start it but it wouldn't turn. I thought it was the starter so the ski would sit for another several years until recently. I didn't know anything on these, nor did I look at any forums because I thought it was the starter for sure. I did things ass backwards with repairing everything at once as I saw it (Starter, pump sleeve, bearings, steering and throttle cable, spark plugs, battery. Even reupholstored seats). I was waiting to see the what problems would exist with the carb upon turning over ). There is no rust on the pistons or in the cylinder that I can tell with a flashlight. One plug is a little rusty at the tip (I included picture). Under the air filter it has some crap in there. I have attached some pictures of that also. I believe the sea doo has the 717 motor. I have pulled the plugs and poured Marvel oil inside so that they may sit for some time. From what I understand, I must turn the PTO counter-clockwise (looking from the rear) in order for the pistons to unfreeze. The PTO unscrews when I do this. Am I turning the correct way? What are my options without removing the motor to get this motor unstuck?
Any advice would be greatly appreciated.
