Chips
I have a 1997 Speedster and can't get in time for this weekend, an OEM boot that covers the axle and connects to the carbon ring and hull insert.
I am thinking my worn out boot is causing cavitation since I have tried every other area if potential issue for the problem.
I am wondering if the more rigid rubber "hose" will function better than the rubber boot that gives under pressure. Will too much pressure pushing the carbon ring onto the stainless steel ring, create too much heat and a potential failure? I will cut the rubber hose to proper length specs in manual (59-67mm).
Here are some pictures of the potential replacement...
