Hello all, I am looking for help on a 97 GTX. I noticed my carbon ring was leaking water at high speeds so I replaced it along with the tophat. Both rubber bumpers are properly installed on the driveshaft, and the PTO has been pumped with fresh grease. The bellows is new as well and is providing adequate pressure on the carbon ring. I even tried the zip tie trick. Everything seems good and tight and there is not any forward/aft free play in the driveshaft. I will say that one of the rubber bumpers was slightly torn, but still appeared that it would function properly. (Waiting on a new one in the mail). I took it for a test drive today and it is still spitting water when I accelerate very fast. It does not do it at continuous low speeds or high speeds, only when I quickly accelerate. It is not just a little water either. It quickly accumulates.
Could a partially torn bumper be causing this? What else could it be? Only thing that I can think of is misalignment. Everything appears to be aligned, however. Open for suggestions.
Thank you.
Thank you.
