Dr Honda
Hi Boy's and Girls,
OK... on my local boating chat board, (boatpittsburgh.com) we were going back and forth on RV antifreeze, and it's effectiveness if it gets diluted. My stance was, it should still work, but not as well as the proper mix. (FYI, the proper mix is 60:40, but that's how it is in the bottle since it's "Ready to use") So... the scientist in me couldn't let it go. AND... since this is good info for the seadoo guys... I thought I would reflect my findings here.
So... here's the experiment.
In the containers below, there is 475ml of fluid. The 2 end containers are our controls. 100% is right out of the bottle, and 0% is tap water. Even though, the "Bottle" of RV anti-freeze is a mix, for simplicity, we will just call it 100%. Also, I was going to use bottled water, but I figure most of us would be diluted with either water from the hose, or the rivers. Either way, it will be full of "Other" stuff, that could effect the freezing point.
Then, as you can see, there is a 75%, a 50%, and a 25%. If you guys would like to see a 10% or some other mix... I will make one.
Finally... take note, that on each container, there is a couple lines. That (more or less) marks the top level, so we can see what expansion happens as it gets cold. This is important since the RV claim is -50 Deg F. BUT... that's a burst pressure. So, I will assume it will start to gel, and expand at some given temp.
The test will be simple. In the morning (and days to come) I will check each for liquid or ice. I will report on what I find.
