Someone help me verify my cooling system is correct on Sea-Doo 587
92seadoo
The clear hose is the hose running to the exhaust manifold. The head that I have on this engine also does not have an extra outlet for a cooling indicator line (which worries me). If someone could please verify if I have everything connected right that would be very helpful. Also if I can add a T to the line that is connected to the head and use it as a cooling indicator to make sure water is coming out let me know if I can do that
Yes it looks good and yes you can get a 1/2 X 1/2 X 1/4 T and put it in the outgoing water line to feed the pisser.
No problem. Be sure to get some clamps(not hose clamps) on that pto boot too. I like the OEM ones best but double up zip ties at least and pump some grease in there.
