wildlifeguy
good evening ladies and gentlemen of seadooforum.com
hope you are all well on your way to this summers on the water experience with your seadoo... cause I'm not.
On a short trip out about a month ago, I blew some bearing (needle bearing) in the port engine.
$1700. later, we get it in the boat on a gorgeous sunny morning and go to start and nothing... like what???
Mechanic says Mpem... other guys (787 xp circuit board repair guy) says its something simpler, not the mpem.
So, Here we go with diagnosis on line fyi
- lanyard connect "click" in electrical both, both starters button press, "click"
in the electrical box again but no start
- lots of ground in mpem, and all fuses good.
- 3amp fuses blown behind control panel - replaced
- there is signal to mpem from dess post and start buttons
- disconnect start safety on drive position sensor on fwd revrse lever
- hooked up circuit indicator on yellow /red wire to engine starters from mpem and tried cranking. no juice but "click" in mpem.
- jumped the "start terminals" (?) in the control box and both engines cranked over great.
So we know there is lots of juice in batt to start, engines turn over great not ceased, pwr to mpem, all grounds good, signal from dess post and start buttons, but nothing happens when normal start proceedure initiated.
So, could it be a heat sensor on exhaust? does the heat sensor shut down engines or just sound alarm when acivtivated
short in mpem?
or is there another simple solution which I just can't see?
the weather is suppose to great next couple of days and on weekend. need to get my money maker in the water, so let the gods of seadooforum work their magic for me.
short in mpem?
