R Rolfie10 New Member Jun 15, 2023 #1 Hi all, I have a seadoo gsx 951 ltd that when you press the start button the starter kicks in and out. If I jump the solenoid its fine. Has constant 12v to solenoid plug with start button pressed. Can anyone help.
mikidymac Moderator Staff member Moderator Jun 16, 2023 #2 Check actual voltage when at rest and when cranking. Typically low voltage will cause this symptom.
R Rolfie10 New Member Jun 17, 2023 #3 mikidymac said: Check actual voltage when at rest and when cranking. Typically low voltage will cause this symptom. Click to expand... Plenty of power from battery. Is there something in the mpem that could cause this issue.
