RXT Steering: How do I lube the steering cable?
BTR
2005 RXT 215HP. The steering has become extremely hard to turn. I need to lube the steering cable (specifically, the end that services the jet pump outlet). What's the procedure? Which grease should I use? Please advise. Thanks.
Okay,,,remove the cable from your venturi first,,,then see if the issue/binding persists,,which i doubt,,,if yes,,,inside the steering column there is plastic sleeve,,,hard to explain,,,that the steering arm rotates in,,,gets displaced,,,however,,,the internal of the cable could be binding,,,
Years ago I used to try to lube the cables but is short lived at best. Replacement is inexpensive and not difficult.
