Any tricks in getting off those original gas clips on the old grey gas lines? Some are out of the way to get at? Also, what's the best spark plug for my 720cc (overbore 1mm)?
I've found most of the time just pull on the line and it will come off without removing the old clamps. If not just use a small screw driver and pry up on the little tab and the clamp will release.
Do I have to pull-out the gas tank to do the replacing? Opps... no need to answer. It was easier than looked. I thought those hoses were on tight! It wasmsuper easy to remove the hoses without removing gas tank.
