Rectifier/charging
Brprxt215
Messages
109
Likes
5
Location
Ny
Water Crafts
currently: 96 XP, 2018 GP1800
Past skis:4 spx,gsx,rxdi,rxt215,rxt255is,xp,gp1200r,SSXI,waveventure
#1
The XP still lives!!!! Now I put a brand new agm fully charged in today. Resting voltage is at 12.5 volts. With it started voltage began to climb up to as high as 13.4 while revving around 5-5500 rpm roughly. Should it jump right up to 14.5-14.8 or does it just gradually climb?
racerxxx
Moderator
Moderator
Messages
10,496
Likes
151
Location
Chalfont, Pennsylvania
Water Crafts
89 SP, 91 XP,(2) 96 XP's, 99 Speedster Twin 800's , 95 HX, 95 XP800, 98 SPX
#2
No, if it gets that high you have issues. 13.5/13.8 is the highest I've seen mine charge and I have no issues.
Brprxt215
Messages
109
Likes
5
Location
Ny
Water Crafts
#3
Thank you Dan. I ran it on the trailer for a couple of minutes backed in the water today. It started climbing with higher Rpms but did not get to 14 volts. I just wonder if there is any way to monitor it if I was out on open water running full throttle for say two minutes. I wonder if it would raise above 14 volts?
racerxxx
Moderator
Moderator
Messages
10,496
Likes
151
Location
Water Crafts
#4
K.I.S.S theory. Keep It Simple Stupid. As long as it's charging it's time to ride. I'm fine as long as I see it charging on the trailer. From there it's just a little daily monitoring on how it starts. Then, I just forget about it and enjoy the ride. If the red battery light comes on then I'll look into the problem.
Users who viewed this discussion (Total:1)
Adsense
Latest posts
Usergroup
