Hi all,
It's been a while since I've posted on here, mostly because my GTX has been running great. I have a problem now though. I have the 'low 12 volts' warning. It is a new battery. I tested the stator and it seems to be good. What I'm wondering is off there is a way to test the rectifier? When running currently the system is not charging, showing about no difference from not running to running. From researching on here I think that the usual failure of the rectifier results in high voltage to the battery. However, the rectifier must also be the 'regulator' as well. I'm wondering if the regulator function of the rectifier can fail and if there is a way there is a way to test that before I start throwing parts at it.
Thanks in advance if you have any suggestions.
Bruxe
Bruxe
