jaybird
I have a 2006 Seadoo Sportster 155 HP, single engine, non turbo. Other than knowing I need a new impeller and wear ring, the boat runs fine, and is a blast to drive. Top speed with gps is only 38mph, which is why I know I need them parts, I hope. The only other thing I have experienced is after running the boat for say.... and hour or more, tubing, crusing, whatnot, I turn it off and it will not crank again for at least 15 to 20 minutes. So we take a swim, and then get back in, and it has cranked everytime if waiting for that period of time. If you try before then, it will struggle, almost sounds flooded or a weak battery. I pulled the battery and had it tested, completely good. It seems this "cool down" period allows it to start evenually. I'm hoping someone else has experienced this problem and will see this. Thanks to all for your help in advance.
