Hi, I have a 2005 RXP that looks like the PTO seal boot has been ripped up. I noticed it after a stone got into the pump with noticeable vibration- stone cleaed but oil later found in the bilge. Oil leaks only with engine running but never got a low oil pressure alarm.
Feeling the boot, looks like it was ripped in half and one half is now missing.I also found a corroded clamp that was broken that was about the right size for the PTO seal - I did not pay much attention to it since it was just serviced and I assumed the clamp had been changed.
Here are the questions:
can pump vibration cause the seal fail or be torn?
What special tools are needed to pull the pump and change the seal?
Is it possible that the shaft was pull towards the rear by the pump (due to the stone), ripping the seal in the process
Also how to you clamp the intake line- there is no way I can reach in there and put on a clamp?
Thanks
Thanks
