I have a 2004 seadoo wake board edition and I believe my drive shaft is slipping inside the pto inside the engine. If that is the case, the pto should have a higher grade of metal(harder) and would not fail but if it was slipping thr driveshaft would be damaged first, correct?
I believe this due to when I looked under the seat, at the shaft, it appeared to slow when revving the engine.
any thoughts?
Thanks
any thoughts?
Thanks
