A_Bred
In short I have gone through a few motors as some may know if you have seen my other posts. My last motor ( I was pretty much lied to about the hours on it or condition). Long story short - 60 PSI at best on compression won't go about 45 - motors done which was a dreaded SBT motor.
So after some searching have found yet another used motor (from the owner of the shop I use). And for a little humor my machine now has the name on the back ---- Named --- " MO MONEY "
He says 110 hours on the motor with good compression. I will work out the details if I decide to buy it and put it in. Can maybe have it in the water again in Aug.
One issue - The PTO. I don't think its an issue but asking if anyone has an opinion.
My original PTO has the crank sensor at 7 O'clock, and the one that was (or is) on the motor he has is at 12 O'clock. --- It is my understanding that I just need to put the PTO from my machine on the motor so the sensor position is still at 7 O'clock position. -- This is on the physical PTO housing.
I would think my electronics are set up to match the position of my PTO.
Once again any thoughts appreciated.
