Pros and cons of del acc pump&rejetting
k_24
I saw this guys video about deleting acc pump and rejetting and puting on aftermarket flame arestors
What are pros and cons of deleting acc pump and rejeting
His specs are for a 97.5 white pipe. I'd run 165 highs with the stock black pipe.
Those filters allow water ingestion a lot easier and that is the root of many 951 failures. If you can keep water out then the ski will run better and there won't be any accel pump to fail. The larger low speed jets help with the 3/4 throttle lean spot that 951's have(some say they do and others say they don't but might as well be on the safe side.
