JJinSC
Hello all, I have been problem free for a while. XP was running fine when I put it up for the winter. Pulled it out to get it ready for this season and it turned over once and stopped. Sounded like battery. Battery was maintained on a maintainer and show full charge on two different chargers. I’ve had two people load tested one at AutoZone one at batteries plus. They all say the battery is good. So, I came back and took the spark plugs out and low and behold out, came a ton of oil. I know it is probably either in crank seals or Possibly oil pump? Not sure about the pump but I read that somewhere. What is the possibility that this was caused by leftover metal from my RaVE valve that came apart last year? Will it hurt if I pump all the oil out and get it cranked to run it this way I really don’t want to split the engine this year.
