Fuel delivery Routeing
Knowing your carbs and fuel system is clean and flowing properly is very important on old motors. A clean fuel system and carbs will go along way to keep you from needing a new motor premateurly.
Open gas cap in case any pressure is in there, then re-tighten. Remove the gas supply line from carb
and put the hose end into a catch bottle. Remove the fuel return gas line from carb nipple and blow a small amount of air chuck pressure into return line. Watch routing fuel flow from
supply in a bottle, IF it routes good, the carb is faulty from a clog or pump diaphram has a hole.
Check pulse tube for clog, it operates the fuel pump with a push-pull or suck-blow as pistons
go up-down in engine case, that is how the mag carb pump actuates route pressure thru the carb, and back into gas tank . A WD-40 straw works good for that. Attach a 2'short fuel line to the tube and if you can blow into the crank-case, its clear of debris.
On dual carb systems, when the mag carb (it gets fuel first) clogs and the PTO carb starves as a result, and that cylinder runs lean, then seizes first. Running lean can cause Glow-plugging and the engine will Rev run-away. Pulling off the lanyard will not help. Asphyxiating by pulling choke and opening throttle may stop engine run-away. Pulling spark wires may injure you and not kill engine as its getting fire from burning piston carbon or red hot spark plug.
Any SeaDoo or other jetski with OEM grey tempo fuel lines will need the entire fuel system rebuilt due to known problems with internal fuel-line deterioration & resin goo clogging up the small internal carborator filters, fuel selector valve and most other fuel system components. Symptoms also include engine bogging at higher speeds (3500 rpm). Continued riding will cause carbonizing & a burned aluminum pistons and engine failure due to lean fuel/air mixtures and high combustion temps. The only solution is to replace ALL the fuel lines with standard automotive NAPA lines, clear race Fuel lines like:
http://fuellines.biz, or equivalent, rebuild the carborators with rebuild kits,new needle & seats, and replacing the fuel selector valve. It is suggested to install a clear glass marine grade inline fuel filter just before the carborators to catch any remaining debris.
Inspect the fuel separator/filter O-ring and gas tank vent one-way check valve.
