Curtbutler
ok so as i was putting my carb back on and connecting the cables i noticed on the cable that is connected from the thottle cable mount to the mount on the oil injector wont spring back. so if you hook it up, pull the throttle wide open the arm swings like it should to wide open and would be injecting max oil, but if you then let go of the throttle the gas cable retracts back but the one to the oil injector stays wot. i have to push it to go back to idleing oil injection mode... did my spring break in there or what? problem is its a real B*%$h to get at without unmouting the engine.
HELP!!!
HELP!!!
