Scrappy996
Sorry if this post is repetitive or similar to others. Here's the issue, I need to probabley rebuild my jet pump becuase the housing is cracking at the 4 bolts, the wear ring is getting old, etc. On top of that, I'm have leaking problems. I'm going to need a drive line kit to fix the boot, carbon seal,etc. Basically I'm doing a huge fix all at once from the engine PTO flywheel out the back.
- this is where is really need help. I'm not sure what I need to order in terms of just kits or parts. I'm looking at osd.com and i know it will cost alot. I'm ordering from USA to Canada and don't really wanna mess this shipment up. If anyone could suggest what parts, kits, seals, etc I need for this big repair I would greatly greatly appreciate the help.
It's a Seadoo 98 GTI 717cc - think the pump housing is 140mm but not sure might be 155mm. Have to check.
And sorry if I'm repeating other posts, just want to make sure this works out right. Thanks!
