So my 951 was going crazy a few months back.. beeping, starting with no key by itself and other crazy things.
So eventually i decided that it was the solenoid for the starter (jumping it started it fine)... meanwhile it sat since feb.. I got the new solenoid and installed it and it does nothing.. no beeps, no trim function or anything. I tested the wires with my multi meter and it leads me to the mpem. I unplugged the harness and reseated all three plugs... then all the sudden it beep beeps. like it was ready to start so i hit the button.. no go still nothing no trim no crank nothing but bilge pump priming.
upon futher inspection my harness plug number 2 is totaly green and corroded. I tried to clean it and it still wont do anything other than the two beeps.
what can i use to disolve the build up?
Does the vts go through the mpem? If not im thinking maybee a ground.
no blown fuses.
no blown fuses.
