I'm changing the oil for the jet pump (97 GSX) 787. When I took the cone off I noticed the O-Ring was pretty loose. When I try to put the cone back on the O-Ring pinches out the side. Tried vasceline, no help. I can't find a new O-ring locally and was hoping to get the ski in the water for this weekend. How important is the O-Ring? I have Permatex Blue RTV Silicone Gasket Maker (80022) which I assume is similiar to the Locktite that is called for in the manual. If I seal the cone to the housing with the Permatex would that be adequate to run the ski until I order the O-ring?
Also what is the purpose of the 2 small o-rings on the top of the nozzle?
