I Want Carpet!
Kariblay
Trying to order OEM Snap In Carpet for my 09 Speedster 150, but BRP is backordered with no end date in sight.
Go to Hydro Turf Website and they don't list a carpet kit for an 09 Speedster 150 - and don't like the idea of having to glue it in and doesn't have the same fitment as OEM....
Anyone out there have a solve for me?
Thanks in advance,
Karl
Thanks in advance,
Karl
Solution, order the hydroturf for the 08' Speedster! Nothing changed. And the OEM carpet is a big pile of crapola. We replaced our OEM carpet w/ turf after one season.
Part Number is SD15
Sea-Doo Sportster 4-TEC (03-05) / SCIC (05-06)
Part Number: SD15
Also fits 150 SPEEDSTER (07-08). Increase the safety and beauty of your jet boat by adding Hydro-Turf traction mats. Mats include 3M self-adhesive for a faster, cleaner installation. Note: If you are ordering Molded Diamond, the ski locker pad must be cut into two (2) pieces due to the direction of the grooves.
Price $290.00
Thanks in advance,
Karl
Buy the Hydro Turf B-stock and PSA (Pressure sensitive adhesives) and do it that way, l have it on my speedster and it is the best turf I have ever used. If you do go this route put it on in the sun and let the sun get if warm before install. Forget the glue use the 3M tape, you can also get that from Hydro Turf.
if you call, and tell them you are a member here... they will give you a 15% discount.
I also agree with what was said above. The factory carpet sux. I've had Hydro Turf in 5 or 6 of my watercraft, including my Sportster, and it's good stuff. Also... pay the extra few $$$ to get the 3M put on the back. It makes the installation quick and easy. I did my entire boat in about an hour. If I was using contact cement... it would have taken all day.
Yeah not only that but the carpet, depending on area, can get moldy gross...:(
What type do you recommend grooved/diamond and cut/molded?
Also, what color would you recommend for a yellow 09 speedster?!
Call and talk to them. They will gladly send samples of different colors and textures. That is how i choosed.
I have a 96 speedster and got the black cut groove, black went well with my color scheme and the cut groove drains water well and is easy to clean. I also have the diamond cut on my jet ski but they are small so I didn't worry about the ease of cleaning on those.
