Dr Honda
So.... the dead cyl came out.  But alt least you got it fixed.
Yes... I changed my fountain pump. The wires aren't easy to get to... so, I cut them close to my pump, giving me a lot of room to work. Then I soldered the wires on the new pump to that. Also... do not use tape on the wires. Use some heat shrink. Coat the soldered joint with a little RTV... slide the shrink tube over it... and let the extra squish out as you heat it.
If you look around... you can find that exact Rule 800 pump, and it makes it a quick job. (it will just pop out of the bottom cage)
