defiantcustomrides
Hello everyone. I've been reading on the forums for a couple weeks getting the basics on these craft. I bought a 97 Speedster that was in really bad cosmetic shape, and needed a few mechanical things. I figured at $1500 even if I had to rebuild both engines, I would still be in decent shape. I own a custom automotive shop, and specialize in custom paint, and electrical, but upholstery, and mechanical are things I can easily handle as well.
I knew the first step was getting the bugs out of it, (as in the mosquito colony living in it), and get it fairly clean so I could get a better look at it.
The boat sat for two years with no cover, and was not winterized. I pulled the plugs, and turned both motors over by hand, and they spun like a sewing machine. This made me pretty happy, but after the cleaning I noticed a crack in the cylinder near the head. Looking closer I found the gasket pushed out, so I decided to pull the head. The bolts were packed with sand, and it took over an hour to remove the head. I didn't want to snap a bolt off, so I took my time with the PB blaster. There was sand in the water jackets, along with salt water corrosion, bulging, and more cracks. These aren't the kind of cracks that you fix, so I know both cylinders are toast. I have not yet pulled the port side, but I would imagine they are similar. It's also obvious that new plugs were welded in the exhaust on the starboard side, and the previous owner never checked the motor. The cylinder walls, and pistons look great however, and I imagine when he said they both ran great, he probably wasn't lying.
My problem now is a top end kit is not going to work with most suppliers requiring good cores. Plus I'm not sure I want to just rebuild the top end, not knowing the real condition of the bottom end. I have been looking for used cylinders on ebay in decent shape to send in for rebuilding, but I fear that would cost as much as a reman engine when all is said and done. Any suggestions, or sources for parts that I am not aware of?
Thanks
Thanks
