speedster4us
This is just to inform everyone to check to make sure there is the correct required amount of oil in the cone, for the impeller shaft and bearings. I went ahead last night and removed everything on the Port Side to replace the wear ring, and inspect make sure everything is OK. (which it was, and also repacked bearings). Reinstalled everything. I then switched to the Starboard Side, went ahead and removed the water lines, nozzle, F,N,R gate and then pump. After removing the cone (which was all melted inside) all the needle bearings and other items, just fell out. The impeller shaft got so hot it burned the metal, and welded the needle bearings to the inside of the pump assembly. After messing around on the press for about 50min. I was finally able to remove the bearings without any damage to the pump assembly. So I went ahead and ordered a new impeller shaft and cone. I was already doing a rebuild on the pump due to alot of noise it was making. So this is a heads up for you guy's out there to keep up the maintenance on your toys. I believe what happened was the impeller shaft collar broke, which then the pump oil emptied out and water came in flushed out the bearings,and then locked them up. Also do any of you guys know what the 2 o-rings go to in the pump rebuild kit. I am not sure where they gne is smaller then a dime and the other is smaller then a quarter.
