Uncle_Tone
Hey guys, on my 98 XPL the 2 rear engine mounts were shot. So I ordered new ones, for rear and front. I soon found out the front mounts are a different height than the old ones but the rears were the same. I installed them all anyways and would align the engine with the alignment tool then shim accordingly. Heres the problem. Even thought the front mount was shorter than the old one that didn't matter, the rear of the engine needed to come down about a 1/4" according to the alignment rod. Only thing is I can go any lower with the rear mounts. I even tried raising the front mount to the old height but that did not help at all. Im guessing I'm gonna have to find shorter rear mounts so I can lower this engine to where it has to be. Has anyone has this problem before?? And which other mounts would I be able to order that are lower than the ones I have?? Finally, I measured the height of the rear mounts, from top of base to top of mount its a hair under 1 1/8". Im stuck in the mud here....
