Linescreamer
I have the alignment tool bolted in. When sliding the shaft forward it just barely touches the PTO prior to entry into the splines. It can be slid forward about 1-1.5" into the PTO but does slightly tap the side of the opening prior to entry. Is this OK? I have tried shimming but still can not get the tool to slide in without a slight tapping prior to PTO entry. It looks like I would need to lower the front of the engine a bit more to avoid this issue. The problem is currently there are no shims under the front mounts and therefore I can't lower the front any more without doing something to the mount itself. What do you guys think?
