Yelloeye
Hi all,
I'm wrapping up an engine replacement on my '98 Sea-Doo GTi and could use some tips on using the engine alignment tool and shims. Initially I had quite a bit of trouble getting the tool to go into the PTO, even without the alignment plate installed. After a lot of pushing and adding a liberal amount of driveshaft lube, it finally went in. There seems to be about 1/2" of free movement at the end of the PTO with the alignment tool installed, it gets a little tougher beyond that.
What exactly am I looking for on this alignment? I got it to be a nearly free slide before bolting it down, but once the bolts were snugged up it was difficult to move again.
Thank you in advance!
