93 Seadoo XP 657
I'll start here..
Fresh engine.
New crank
New pistons
New Rotary Valve
New Rotary shaft
new impeller
new wear ring
Rebuilt carbs Mukini kits
Black fuel lines with inline filter right before carb
I lined up the Rotary valve with the mark on the case. and MAG tdc .
Could i be off one tooth??
or half?
this seams to be a Normal problem with the 657 and timing..!!!
i can ride it .. but starting off.. it makes it right to 4000 some times 4500.. but says right there and pauses for any time.. 3-10 sec.. dependin on the load.. acts like it is loaded up..
when going full bore.. when u get there is kinda ok.. you hold it there it is ok.. full power is what i think, but no throttle response if say u let go just for a sec or 2 .. u have to wait again another 3-5 secs then takes off??
kinda boggy..!!!! no sudden acceration??
What am i missing...
any help here??
one guy said to try jetting.. the mains down a jet!
after he looked at the plugs?
it is stock jetting. stock air box
yes.. i lost one of my bolts off the carb throut too. yes. Ran great before????
thanks guys
I'll start here..
Fresh engine.
New crank
New pistons
New Rotary Valve
New Rotary shaft
new impeller
new wear ring
or half?
any help here??
thanks guys
