griffith1230
Sea Doo Friends,
I would appreciate your advice on a problem with my 96 XP. I pulled the ski out for the first time from winter with a few problems. I knew when I put it up I had a problem with a stripped shaft or PTO. When I first tried to get it to start it would not turn over. I came to find out that it had a bad solenoid. I have since replaced and did get it to turn over.
The problem now is that the ski will barely give me 2 beeps. Most of the time I put the lanyard on and get no response. I can try several times and sometimes get it to respond with 2 beeps. Most of the time, nothing. Any suggestions? I have had one person tell me that the posts do not usually go bad. Is it most likely the lanyard? I have had intermittent issues with it before, but not this bad.
If I do need a new lanyard, where is the best place to get one and get it programmed?
Thanks,
Jacob
Temple, GA
Thanks,
Jacob
Temple, GA
