JPass
The sound happened instantly when I was driving with the lose of power.
The same issue out of the water. The sound is not the normal sound with or without water. It is higher pitched/violent. The wear ring looked pretty normal. There were like tiny scrapes but barely anything a finger nail could grip to.
Friend confirmed the rear was spinning but said it looked "wobbly". Not sure if that matters.
Here you're saying your friend saw the impeller moving correct? If the impeller is moving, then more than likely, there's nothing stuck in your pump and you need to look elsewhere.
Once you have the chance, put her on the hose and take video of the sounds she's making as well as what the impeller is doing. This would be extremely helpful in trying to figure this out.
