despower
I am about to change my jet pump oil (yes, I should have done it last fall). In my Sportster Shop Manual, it suggests using Loctite 518 Gasket Eliminator on the jet pump cover when resealing the pump. Loctite 518 is an anaerobic flange sealant. Unfortunately, I haven't had much luck in tracking this stuff down locally. Most stores (even my Seadoo retailer) only carry aerobic cure gasket maker like Permatex Blue, Black or Copper.
The closest I can find is Loctite 515, which is an anaerobic gasket maker, but obviously not the same properties as 518. I have read through the spec sheets of 515 and 518 on the Loctite website, and most of the info is gobbeldygook to me.
So, my question is - why do y'all use to seal the jet pump cover when you change your jet pump oil? Any advice is appreciated.
DP
DP
