Can't start my ski
DJ Dome
After rebuilding my carburetors on my 94 seadoo xp my ski started right up i got it to idle. I put it in the water and it needed to be leaned out just a little. So I shut it off adjusted it and tried to start it. It didn't start up. So I put the adjustment back to where it was and it still won't start up. Anyone have any ideas as to why I can't get it started now. It started every single time. It turns over. The compression is good. It's getting fuel. Do you think it could have fouled out brand new plugs that fast? It was less then 10 minutes just at an idle. I even put the old plugs back in and nothing. Keep in mind I did all the fuel lines, fuel selector, changed old gas, cleaned fuel filter and a complete rebuild of both carburetors.
Are you sure you have your lines routed correctly? Not being rude, I've mixed a return and supply line up myself
Yes all the lines were replaced one by one. As soon as I rebuilt the carburetors it started right up a bunch of times. It wasn't until I had it almost tuned I went to lean it out a little. I shut it off before I did it n went to start it n I can't get it started now. I even started over n put the low adjustments all the way in again and set it to 1 1/4 out. Still nothing.
