Seadoo 717 hard start
I went ahead and replaced the y fitting today. Pressure tested the carbs again with all the hoses in place (except the return). Pressure held fine.
Ski was hard to start on the trailer today. I probably cranked it for a solid minute or two, in 30 second intervals. Some of that time may have been getting fuel into the mostly dry carbs. Took the old plugs out and put paper towels over the head and spun it over to see if fuel was coming through. Towels had a small amount of gas on them, so it looked like I was getting fuel through. Put in new BR8ES plugs and spark testers so I could visually see spark. Spun it over 3-4 times 30 seconds. Would not start. Was finally able to get it to start by giving no choke and a bit more than 25% throttle. Ran it on the hose for 5 minutes or so while I tried my best to set low idle to 3000rpm.
It started at a pretty low rpm 2500ish then I revved it a couple times and it jumped up and then fell back down to around 3500ish. Thus began my back and forth attempts to adjust the idle. Turned it back out (left) a turn, revved it, then the rpms were too low again 2200ish. Turned it back up a bit (less than a turn), revved it, rpms were too high. Turned it back out a small amount, then I revved it, checked rpm again. Rpm was 3150. Revved it some more, 3200. Turned it back down a tiny amount, revved it under 3000. etc
I don't think I have addressed my issue with difficult starts. It seems that the issue is likely due to fuel delivery when I go to start the ski. Most likely carb-related. Gonna go try and put the ski in the water and then idle around for 30 minutes or so and come back and check plugs @burtshaver2021
I’m grasping at straws, not sure if this makes any since or not as I can’t recall anyone mentioning for sure exactly how they work but it seems you don’t have any fuel available when you go to start it. I’m wondering if the first Mylar disc on the fuel block , if it were leaking or if there was a hole in the grommet that holds it in place, if that would allow fuel to drain back out of the fuel block? Also when you were checking the 3 small holes in the carb throat, did you verify that carb cleaner was coming out of there? I know you said you seen it coming out the big hole for sure and out 2 of the small holes for sure, but was it coming out all 3 small holes?
Also where are you set at now for the low speed screw?
I took the ski out a few hours ago. Basically feels the same as it did before. Same throttle responsiveness, same speeds. I was at 1 turn out from closed on the low speed screw. This time I set both carbs to 1.25 turns out from closed. I also adjusted the throttle synchronization so that the throttle positions are a bit more in sync than before. I verified this with a bore camera. Both throttles open to the same positions roughly as observed from the naked eye.
When starting the ski, this time I've discovered that i just need to give it 25% throttle and it will usually start within 30 seconds. I started the ski that way on the water, verified 1400-1500rpm with tach (at launch my idle was 1400ish rpm. after punching it out of the no wake zone and idling back down, I got somewhere around 1500ish rpm). Drove it around for maybe 30 minutes to an hour. Let it sit for 15-20 minutes. Was able to start the ski the same way, 25% ish throttle.
So to recap:
Reset rotary valve timing to within +3-4 degrees of spec (tolerance is +-5, verified 3 separate times with dial indicator)
Checked rotary valve lash at 0.013-0.014 inches (spec is 0.010 - 0.014in, verified 2 times at 45 degrees with oring of cover removed)
Replaced battery as it failed load tests
Compression tested at 133ish lbs per piston. My rebuild a few years ago yielded 135psi per piston
Tested spark
Reattached exhaust pipe (separate issue, had come loose and was spraying water into hull)
Tested carb popoff. Mag side carb 40-42psi. Pto side carb 35-36 psi . Both carbs held 10psi pressure for several minutes (individually, and connected together).
Found y fitting of fuel line leaking air. Replaced. Performed pressure test of carbs again. Held 10 psi pressure for several minutes. No leaks
Brought idle of carbs up to 3000-3100 rpms on trailer. Around 1400-1500rpms on water.
New spark plugs. Verified gaps
@burtshaver2021 if i'm able to start the ski with only 25% ish throttle and no choke, wouldn't that imply I'm running slightly rich at startup/starting? The weird thing is, until July of '25 I was running the carbs a bit more lean than the manual states. I had them running at 1 turn out from closed. Now they are at 1.25 turns out from closed, like the manual says. The manual says to turn the low speed screw in/out 0.25 more/less than spec to help with tuning. I already was at that position before making this thread. Should i turn the low speed screw in 0.50 turns on both carbs to help lean it out?
The fuel block may be the next thing I check. I recall having difficulty installing that rubber grommet for one of the mylar discs. I don't think I replaced the other because of how hard it was to install the first.
Attached are the new plugs after running the ski no more than an hour. Most of that time was idling through no wake zones. I may have run the ski full blast for 10 minutes overall. Also the plugs smelled like the full synthetic oil I'm running. I've verified my oil pump timing is perfect, right on the mark.
I’m really at a loss as to what to think, those plugs look rich, Stock settings is 1 1/4 turns out correct plus minus 1/4 turn? I wouldn’t turn them in any more than the 1/4 turn that’s allowed, putting you at one turn out again. Everything is stock correct? Air box? When reading the plugs, you have to use new plugs and then drive at a certain rpm only , in your case I guess that would be at idle where the problems are correct? I’m on vacation at the moment and don’t have my laptop to read through the mikuni carb manual. There is a test in the manual for those discs.
Just reading the Seadoo source specs for your machine. I see pop off listed at 36-60 with 55 being optimal. That’s how I read it anyways. I’m almost positive these work best when they are in the higher part of the pop off range and yours is low, within range, but very lowIMG_5071.png. Did. You get new needle and seats with the kit from OSD? Where they 1.2 needle and 80 gram spring? Did you order the new levers with them? Odd that they are so far apart and quit low. Did the levers sit flush with the carb body? Did you bend them? I don’t bend them. I was baffled but after reading through your posts again and looking at the Seadoo source page, could be on the right track here as the pop off does affect up to 1/4 throttle . I will check back and see what the specs were for my HX and XP. But I’m sure they were popping in the higher portion of the range
The pop of was listed at 40-56 for my 95HX and mine popped at 50. Ran great. I’m thinking your pop off is to low. Either the wrong spring or the lever is bent.
@burtshaver2021 I ordered OSD1272 from osdmarine back in October of '21. The email I received indicates that i ordered the optional needle arm/pin set as well with the back to oem kit.
1 x OSD "Back To OEM" Sea Doo Dual Carb Rebuild Kit (1995-1997 717) (OSD1272)
Fuel System Opt. Extras Needle Arm/Pin Set
According to OSDmarine those needle valves were 1.2 OEM MIKUNI Coated VITON. I remember replacing the needles and seats in these carbs with those from the OSD kit. I'm not sure about the gram weight of the springs. But they were also replaced with those from the OSD kit. I'm not 100% positive about this, but I might have bent one of the levers up a bit. I can't remember if that was in the seadoo carbs or another toy entirely.
I may see about ordering just the fuel pump check valves/grommets (grommet install tool too), levers and springs for a 717 dual carburetor. Or just an entire kit and keep some parts on my shelf.
Everything is OEM on this ski, except for 1mm over pistons.
I wish someone else would comment here on this but I’m pretty optimistic on the pop off being to low. Pop to early allowing more fuel in. Your plugs look rich. Symptoms indicate that it’s loading up on fuel.
Like
Report
[ATTACH type="full" alt="Dr Honda"]68291[/ATTACH]
Dr Honda
Well-Known Member​
1) Yes... people do it all the time. They don't know about properly setting the carbs... and they just throw in any spring they have.
2) If you have a spring that is getting you to 28-30... then you are close. I would use that, and bend the arm down slightly. That will get you to the 30/32 range, and then you will be in spec. (do not bend the arm down more than 1mm past level with the carb body)
If you run the pop-off pressure low... you may cause the bottom end to be a little rich... but that can normally be corrected by turning in the low needle a little. If the pop-off pressure is excessively low, you could get a hard starting problem. (it will act a little flooded) also, you could get a mid transition that is a little rich. BUT... at 30 PSI, it shouldn't have a problem.
As always with a 2-stroke... you want to error on the rich side to be safe.
Found this post which confirms my thoughts that the low pop off is causing a rich condition on the low end.
Like
Report
Dr Honda
Well-Known Member​
@burtshaver2021 Is the popoff for both of my carbs too low? Or just the one reading 35-36psi? Because both plugs look identical. I have a dual carb 717. I'm not sure whether there would be a significant difference in plug fouling with a 5-6psi popoff difference between the 2 carbs. I have run a few sets of plugs in these skis and they both look identical when I go to change them out.
I think it would be better if they were both raised. I would message Nick through the OSD website to be sure of the correct spring. Mention your make and the desired pop off. And order new needle pin levers
This thread says it is 1.2 needle with 95 gram spring.
Post number 6 in this thread says a 1.2 needle with a black 80 gram spring, so I don’t know what to tell you. The previous post said a 1.2 with a 95 gram spring. Pretty sure Seadoo source says 80 gram. But I do believe your pop off is to low and that you need new levers because they have been bent at some time
Hmmm. I'm pretty sure those springs in those carbs were that dark black looking spring. Got those from osd in '21.
According to seadoosource :
1996GTI717270500278270500279BN-38I (SB)MAIN-130 PILOT-67.51.2270500267 (80)55 psi (36 - 60 is manual spec)LOW- 1-1/4 HIGH- 0-
I feel like I've heard I'm supposed to be using an 80 gram spring, and I probably am right now. I can ask osdmarine about the ones the provided in their kits. But maybe that 95 gram spring would help my issue. Looks like that would raise popoff by about 10psi. I'll ask osdmarine about all this.
1996 GTI twin carb should use 80 gram, black springs. With a 1.2 seat you should be close to 55 psi pop-off. If you are at 36 psi something is not correct, either the seat, arm or spring. Those are the only 3 things that control pop-off.
I went ahead and ordered x2 1.2 needles/seats, 2x 80 gram (SEA DOO 270500267) springs and levers, and x2 screw/retaining plates for the needle/seat. Ordered from osdmarine.
2 ea. VALVE-NEEDLE 1.2 (SEA DOO 270500263)
2 ea. O-RING (SEA DOO 270500127)
2 ea. LEVER-VALVE (SEA DOO 270500128)
2 ea. SPRING (SEA DOO 270500267)
2 ea. SCREW (MIKUNI - NEEDLE VALVE PLATE RETAIN) (SEA DOO 270500155)
2 ea. PLATE (RETAINS PUSH IN NEEDLE SEAT) (SEA DOO 270500125)
I received the parts today.
PTO carb: Installed new 1.2 needle/seat, retaining plate/screw, and 80 gram (black) spring/lever. Popoff measured 49-50psi.
MAG carb: Installed new 1.2 needle/seat, retaining plate/screw, and 80 gram (black) spring/lever. Popoff measured 39-41psi.
Before replacing parts in the carbs, I went ahead and re-verified popoff measurements I had taken previously. Mag side carb 40-42psi. Pto side carb 35-36 psi. Checked and rechecked several times. I have 2 different pressure gauge testers that I have used this time and measurements are consistent between the two. The first carb I worked on was the PTO side. Once I got it set and measured it probably 5 different times with both testers, I then started on the MAG carb. I started by trying the new parts. After that yielded no noticeable difference, I tried swapping in/out all of the black springs I had (3, one new. 2 previously used in these carbs) and different levers. Bent one of them very carefully, but it never seemed to really make a significant difference. Checked and rechecked popoff pressures several times for each spring/lever combo. When replacing these parts I used the pinned carb rebuild thread as a reference. Used a razorblade to make sure the lever was level with the carb body, etc.
I did notice that I had apparently used 2 orings previously on the needle/seats. The needle/seats that came from OSD already had the orings on the seats, so I ended up not using the orings I had ordered. I also took the liberty of cleaning both jets in each carb. Notably, the pilot jet in the MAG side initially had limited flow through the inner most tiny hole (closest to the throttle plate). I shaved down a copper wire I had and used it to clear the hole. As of now, both carbs have full flow through the pilot jet. I'm planning on adding these filters inline before the carbs to prevent this in the future. I've heard decent things about these on one of the seadoo 2stroke facebook groups.
I need to order a few sets of carb gaskets for my skis, so I'm gonna go ahead and order those and another 80 gram spring, 95 gram spring (for testing purposes), a new lever/pin, and new screw for the lever/pin. I'm pretty sure the new seat is sealing with the MAG side carb, so maybe the problem is with the lever/pin screw.
Absolutely DO NOT add those inline filters. You only need the factory fuel strainer and the small ones inside the carbs.
I always replace the levers and lever pivot pin. No reason to replace the screw unless it is damaged.
Facebook group...:D:D:D More bad information than anywhere.
After installing new 1.2 needle and 80 gram spring from OSD the PTO pop off is now 49 to 50? Up from 35 to 36 correct? And the mag side after installing new 1.2 needle and seat, mag side carb is popping at 39 to 41 which is basically identical to before you put the new needle/seat and spring in. So huge gain on the PTO carb and no difference in the Mag carb. Maybe that will make the difference but weird that changing them would affect one and not the other, maybe you already had the 80 gram spring in the mag side? Before changing them recently? Did you put new needle levers in as well when you recently changed the springs? Something is different with the mag carb and it shouldn’t be
Yeah everything you said is accurate. I feel like maybe the retaining screw for the lever/pin was damaged. It felt different tightening that one down on the MAG side versus the PTO side. Yeah new needles/seats/springs/levers. Replaced the seat retaining clip and screw too. Kept the lever pin and its retaining screw. Gonna replace those this next time around and see where that puts me.
We may be using different words for the same part but just to clarify, did you replace the piece that the button of the diagram pushes and the other end lifts the needle? I’m calling it the lever. Yes, if the screw that holds the pin that the lever swivels on is not correct, that would do it, but it should either be screwed in all the way or it’s not. Hopefully didn’t cross thread where it screws into.
Is there a particular reason why this is a bad idea? I thought to do this because of an issue with a different ski I'm having, and because I did notice one of the pilot jet output holes was partially blocked in this ski I'm currently working on.
The other ski is idling low. Turning idle screw up does bring the idle up momentarily, but it falls back down to 1300-1400 rpm. Ski runs fine at high rpms. Figured I have an obstruction in the pilot jet. But that's not related to this thread :)
Seems like the factory fuel strainers/etc aren't good enough to prevent blockages in the carbs for very small particles. When I got each of these skis a few years ago, I completely went through the fuel system and replaced all of the grey fuel lines, rebuilt all carbs with osd kits, disassembled the fuel tank and cleaned/degreased, changed both pressure valves for the fuel system, replaced the square cut oring and strainer (in the water separator thing i think its called), replaced fuel selector, etc. Completely went through the fuel systems for both skis. I figured I would use these filters just in case. They are high flow, low pressure so I figured they would work pretty well. I've used some of these before on a crankcase pulse fueled type small engine.
I have replaced #23,24,25,26,27,37,38 in this diagram
I will be replacing #26,27,39 again. It is the first time I will be replacing #39, and its retaining screw.
I'm pretty sure I didn't crossthread it. It just felt like I had to turn it more than the other to get the flange of the screw to meet with the carb body. Maybe the screw on the MAG side of my ski is a bit longer than the other. I have ordered a replacement screw pack for the MAG side carb to potentially resolve this.
They restrict fuel flow and cause them to run lean. They are not needed.
The fuel strainer catches the majority of junk. The little filters in the carbs catch anything smaller. Anything smaller than that will pass through the jets. Your jets plugged from old fuel, not from anything going through the filters.
