Skirta
I have a 1997 Seadoo XP that I brought back to life. New MPEM, new (used) and rebuilt carburetors, new fuel lines, new fuel switch, new fuel filter, new starter, new ignition coil, rebuilt oil pump, and new plugs.
It ran fine for a while but now it is running really lean and backfiring horribly. If I try to run it at WOT it leans out enough to die or barely runs at all. It isn't shooting oil out of the pistons so I think the inner crank seals are fine.
There is oil in the hull but I spilled a bunch in the oil pump rebuild so I can't tell if one of the outer crank seals is the problem. Basically I'm at my wits end because I can't figure out why it started doing this.
Any help or suggestions are appreciated. I've done all the repairs myself so far and I grew up around two stroke engines so I think the work has been done right so far.
