coolhand86
I have a 1998 Seadoo GSX Limited that is experiencing significant battery drain. I have searched the forums and tried many things, but I am at a loss on what to do next and could use some help please!
I acquired this ski a few months ago and had the carbs rebuilt (not time to do it myself). The shop told me the battery was dead, so I had them put in a new one. When I picked it up from the shop the next day, the battery was dead again. I charged it up and the ski started up fine and sounded good. I took it to the lake and rode fine for about 45 minutes to an hour (this thing is fast!). Then all of a sudden I lost most of the power and could only ride very slowly. If I pushed the throttle much, it would bog way down like it was about to die. I was close to the ramp and slowly made it back. Once back home, I found that the battery was dead again. I charged it up and unplugged the VTS and gauges from the MPEM. 3 days later, the battery was dead again! I charged up and unplugged the stator connector and there was no drain on the battery after 3 more days (checked with voltmeter). I plugged the stator connector back in to the MPEM and the next day the battery was down from 12.5V to around 11V.
I checked the continuity between the three yellow stator wires and received a reading of 0.1 ohms (or it may have been 0.0 ohms, if that is even possible??) on all wires (1-2, 1-3, 2-3). I checked each yellow wire to engine ground and the meter had an infinite reading, so the stator seems good. The battery voltage when charged up is between 12.2V and 12.5V. The battery voltage reads 13.4V when the ski is on and running half throttle, so the regulator seems good. I checked all the fuses and they are OK.
One other thing to note, I have never heard any beeps when putting the key on the post. Also, the info gauge does not power up and I am not sure if this is related (I purchased a new used info gauge and plugged it in, but it does not work either).
Any thoughts on where to look next?? Thank you!!
