Dirtbikes4fun02
i found out today that my seadoo has a leaky exhaust gasket. and it also has a big crack in it causing the hull to fill with water.
i am wondering if my seadoo has a "limp mode"?
cause it seems to run fine for about 5-10 minutes then it will NOT rev above 4k.
if you let it sit and cool down for a while it will run purdy good for a few minutes and then the 4k limiter comes back. while this 4k limiter is happening, if you shut it off, it is a royal pain to restart! it takes forever to start and when it does fire up, it will die with the slightest bit of throttle.
but if you let it cool down for about 30 minutes, it starts working just fine.
could this leaking exhaust be restricting the cooling ability of the motor and causing a "limp mode"?
could the exhaust leaking possibly cause the sharp jumping of the upper rpms when not in "limp mode"?
im sorry to keep asking but, i just got her home today from the shop. i gave up. i have too many aftermarket parts for the premium troubleshooting on this site to help me (that was what i was told), and the shop today told me to come pick her up because they wont work on it having so many aftermarket parts but they did tell me the exhaust was leaking pretty bad.
after following the advice of some very respectable people on this board. i replaced all of the fuel lines, cleaned the selector valve, and cleaned the carbs (which looked better than new inside). which didnt help the problems at all. all the fuel lines were already replaced prior, but i did it again anyway. so now i can say "i am pretty sure it is not fuel". lol :thumbsup:
now the guy who built the motor for this ski told me that he cannot work on it because he sold his seadoo dealership and he has a "no compete contract"... but over the phone he promised me i would be wasting my time looking at the fuel system, cause he was almost possitive it was electrical somewhere either loose or malfunctioning.
i have called every marine mechanic within 3 hours drive from me and either they dont work on seadoos, or they will not touch it because of the mods. BUT, i have been advised by 4 people that i should take it to Jet Thrust Performance in Lawrenceville GA because the guy there is the absolute BEST and works on aftermarket/performance skis.
Sooooo.... thats AWESOME!... not really... the guy they are talking about is the same guy that built and sold me my seadoo, and he sold Jet Thrust a lil while ago. He is the only guy they refer me to, and he cannot work on my ski because his shop is 3 doors down from his old shop. he now does boats ONLY, and is scared of a lawsuit if he touches my seadoo, cause he works soooo close.
somebody PLEASE help me! i am beggin :hurray::hurray::hurray:
mods:
decker stainless tuned pipe
dual 38 super bn carbs (i dont know the jet sizes, but its got 2.0 N&S)
dual ocean pro vortex flame arrestors
blue ocean pro head
solas concord impeller
worx intake grate
fuel primer instead of a choke
that is all of the mods i can see visually, but i am sure there are more supporting mods in the motor and outside that i havent noticed.
and the compression is just above 180psi on both cylinders.
mods:
blue ocean pro head
worx intake grate
