Background:
I have been trying to troubleshoot a problem I created by connecting a battery charger to my ski and cranking it right after I purchased it and it immediatly started blowing the 5A fuse. I replaced the MPEM with a used unit off this site and it continues to blow the 5A fuse.
Either I have another bad MPEM which is entirely possible or there is another problem causing the fuse to blow.
I ended up measuring all of the connections and this is what I found is blowing the fuse: The DESS key has 3 wires feeding the terminal. There is a magnet inside the key which connects wires 2-7 and 2-15 as you plug on the key.
I found that 2-7 is Ground wire but the 2-15 wire originates inside the MPEM and I have not determined why grounding this wire blows the fuse. I then cut the 2-15 to separate it from the terminal and did verify the fuse stops blowing but now with the key on there is no activity.
Does anyone know what 2-15 lead does or maybe what some next steps should be to repair the ski? I am thinking this is the location of that diode that people discuss that shorts out when connecting a battery charger.
Other background info:
I tried disconnecting the VTS, magneto, and other items to see if the fuse would stop blowing without success.
Thanks!
Thanks!
