1996 Gsx 5a fuse keeps blowing.
Moake90
Hi,
On my 1996 Seadoo GSX is completely dead and the 5a fuse keeps blowing. I’ve already replaced te rectifier but unfortunately no progress.
What I noticed is that the fuse only blows when the stator plug on the flywheel is connected.
Is this a 100% the MPEM? And can I replace a diode like on the later models?
If yes where is the diode located?
Thanks in advance!
Regards AJ
Hi Toby,
Thanks for replying.
I indeed checked the yellow wires with the engine case. But now I'm thinking about it there must be a ground wire as well right?
Yes ground wire. Black
3 yellow, for charging
Black yellow and yellow white for trigger coil
It seems to be the diode in the MPEM. I have measured it and detected a connection between both sides. I ordered the diode and will solder it in.
So fingers crossed. 🤞🤞
