Codestin55
Okay here’s my long shot. I bought a 1997 GSX and GTX a couple weeks ago to work on and learn on (motorcycle mechanic of 9+ years). Full rebuilt the engine on the GTX and the carb. Took it out twice this week and it ran good besides a weird hesitation. The machine wouldn’t rev out fully unless you let off throttle and then punched it again but plugs looked fine and never bogged down and died out just seemed to not want to fully hit on the power. Well I took the carbs out and double checked pop off ect made sure everything was rebuilt with OEM Mikuni parts. Took it out yesterday and it started up great and idled perfect. Took it slowly out past the no wake and went to take off and it died twice. Finally got it started up and got it going (had to do the weird throttle release and punch deal) anyways got it about 100 yards at wide open and it completely died like no lights on the dash ect. Immediately opened the coil box and saw the 15amp fuse blown. Towed the ski out put it on the trailer and didn’t touch it till that night. Well I put a new 15amp fuse in and still dead. Figured I’d check power fuse on the MPEM and the 5 amp was blown. Replaced both of those and it started first crank on the trailer. Ran it about 10seconds and it was fine. Came out this morning and it started right up no issues. So my question is what would cause this. Right now everything I’ve read is seemingly glaring to me that it’s a regulator rectifier issue but I wanted to get any second thoughts. It’s my understanding that if an over voltage situation happened from both ends of the rectifier the front 5amp and rear 15amp would be the first thing to go. Also I hold make sense why it acts so weird despite the fuel system being completely gone through. Anyways I wanted to grab you’re thoughts before I order a new regulator.
