I'm sure your correct, FYI I bought a repair manual and it says to put 23ml or .8oz us grease in the bearing and the same in the cone and reassemble, this amount is really about half the tube you buy from BRP, the picture in the manual shows the cone being filled with a syringe and it is completely 'full' of grease in the picture, strange because if you use the entire tube it fills it exactly the way it shows.
