Dealerships are not the best option in my case. ive taken it to a few and talked to countless on the phone and everyone acts like im wasting my time and they arent gonna be able to help me because that boat is so outdated that they wont be able to work on it.. the closest one that even gave me a little hope was about 200 miles away and i dont feel like pulling it that far just to find out that they cant help me so i decided to try and take it on myself the best i can. i know just enough about electronic ignition to get me in trouble. i can fix ignition systems that have common distributor/points in my sleep but this computer/dess/mpem stuff is gonna give my grey hair way to early in life.
Ill try to describe what the boat is doing. Its very random so i apologize but its the best i can describe.
Three days ago boat ran fine. Put key on post, got two short meduium volume beeps, hit starter button and motor fired and ran
Next day went to take it out. Put key on post, got two short medium voulume beeps, hit starter button and motor turned over well but didnt fire. Let off stater button and tried again and got nothing. No cranking at all.
checked all fuses, good. Checked all wiring connections, good. Jumped starter solenoid with screwdriver, mover turns over just fine but no fire. Put key on post and still got the two short medium volume beeps.. it did this with both keys i have. Then i started to get one long beep if i held the starter switch down for more than a second.
I decided to drag the boat back home and get out my volt/ohm meter and do some checking.
When i got home and was gonna get started on it, i put the key on and got nothing, not even the beeps now. i know the battery and battery connections are good cuz the bilge pump, blower and lights would still come on and the starter would still turn the boat over when the solenoid was jumped with a screwdriver.
i figured the vibration from the ride home might of changed something.
Later that day i went back to work on it and when i put either key on, i heard the faintest single tone from the bell. It was so quiet you can barely hear it but its there.
This is what ive checked so far.
The black wire with a yellow stripe is hot going to the post.
The starter switch ohms out and shows to be good.
The red/yellow wire is hot to the starter switch, when you push the button, i get juice on that wire goin into the left side of the mpem but nothing coming out the other side of the box so therefore no juice to the relay on the starter solenoid.
All fuses show to be good.
I want to know what i should attack next with my volt meter to narrow the problem down to find out where the problem lies.
