New interstate battery checks out..
Fuel is good - it runs great once started.
No spark until I run left for 10 plus minutes.
Compression 165 on all 4.
Thks
Unfortunately its the wrong one... Anyone else have any ideas? Does msd have a unit to replace this? Or can it be repaired? Or is it broken? thks
I have the exact same problem on my 98 speedster. I've changed the stator, pick up coil, have swap coils from one motor to the other and nothing. It will eventually fire after the Port motor has ran for 10+ minutes.....seems like I have no spark on starbord engine initially. once I get it fired it is good all day......I am entirely lost! Everything tests OK as per the service manual but she just doesn't spark.
What ended up being your issue ? I am fearing it may be the MPEM
The reason you weren't getting help or answers... other than from the OP... is because you should have started your own thread.
But... it looks like you guys have the EXACT same issue. Electronics don't normally do what you are describing. It almost sounds like there is an issue in the "Logic" of the microcontroler.
As far as repairing it... Who knows. If you want to try to rip away the potting material, and see if there is any damage... that would be a good place to start.
