Hello I recently purchased a 98 challenger as a fixer upper. I bought it from a guy who had both motors running but after he did some work lost the starboard motor.
I pulled the motor for a couple reason the main reason is the valve cover needs replaced and had some head bolts break.
The other reason was I thought the coil trigger might be bad. But I found a bolt broke where the ground wire where supposed to be connecting the two motors together. I believe this was my no start problem but want to double check my stator and trigger before I reinstall. Can u guys help?
I'm also open for suggestions and tips for items that I should address. I'm an office guy by day but took diesel school 15 years ago so please be patient: thumbsup:
To do list as of 7-12
Change steering & throttle cables - check pump clean out cables
Remove broken studs and reinstall valve covers
Check stator and trigger coil
Recover upholstery
Service as needed
Recover upholstery
Service as needed
