dgoodwin10
First, let me thank all the regular posters on here...this site is the only reason my Sea Doo is where it is today! Here is a little history on the GTX. I bought it in January from a guy who was a Sea Doo mechanic that needed to unload a project. He had run it for several years and last winter failed to winterize it (which he repeatedly admitted that it was stupid on his part). It managed to crack the jug water jacket, but still ran fine. After getting it home and tearing into it, I found the pistons and walls were scarred pretty bad. I ordered up SBT pistons that were .5mm over stock. I had a local machine shop bore the jugs and a welding shop TIG up the jug. While I was at it, I replaced the dreaded grey fuel lines and the coil (my bad). I got everything put back together and it fired right up. I ran it for a minute on the hose at my house. The small hose that connects the jugs and drains the water out of them had a split in it, so I pulled the exhaust off and replaced that hose. This is when my current problem arose. I had been using the battery out of my 4 wheeler to start it, which had been working fine. After I got the hose replaced, I can only get a 1/2 to a 1/4 of a turn from the starter before the Info Center goes blank. I get the 2 beeps when I put the DESS key on it. All the fuses are fine, the battery terminals and the power cables have been cleaned, and the battery was charged, all getting the same result. I also tried using my truck to jump it off (not running) and still got nothing. The starter solenoid was by-passed with the same result. Everything I have read is pointing to the starter being bad. Anything else I need to try before I completely drain my savings on a new starter? And feel free to ask if anything needs clearing up...its hard to focus when you're so frustrated you want to sell it!
