Hoffman33d
ok here is my problem it wont idle and if you get on gas slow it bogs a lil then sometimes takes off and some times it dont but if you get on the gas fast it runs like a top and if it is bogging from pushing the gas slow if you let off it and get right back on the gas fast it goes good like it should ok this is what i have done so far to it changed all the fuel lines cleaned the carbs twice changed fuel selecter put in line fitler in and cleaned the inline filter that was already on there set the highside on the carbs to 0 and low side to 1 1/4 set the idle cable out as far as it will go so it cant adjust it no more any help please
