Have just bought a 01 gtx, was told it runs perfectly. When we went it looked at he started it up quickly and he only ran it for a few seconds because of no water. So we figured should be good. When we got home and it had it hooked to our hose it would idle fine and when you would try to rev it up it would sputter and die.
We took the carbs off and rebuild them with genuine rebuild kit. Still nothing different. Could idle tell the tank ran out of gas but wouldn’t rev.
So we thought maybe getting some fuel but not enough fuel. Like the pump on the carbs was bad. So we tried a 2psi pulse pump from like a tractor. Still the same. So pump on carbs is good and hooked back up.
My uncle came over yesterday and listened to it, he called it a lean bog. But when you take the spark plugs out there soaked with gas.
All the fuel lines have already been changed from before me. We cleaned and replaced filters.
Don’t know if it could be something electrical. The ECU in the front of the pwc says it was changed in 2023, Maybe this is still a problem from then that know has had solved.
And does it make a difference on running in the river or a lake compared to a hose in my driveway?
Any help is appreciated, thanks
