After about 45 mins of riding it stalls at WOT and even at idle. But it fires right back up, then stalls when I give it throttle. Compression is 140/140psi, checked connections for corrosion and dielectric greased. Also cleaned sedement cup and filter. I called the dealership and they said it was most likely an electrical problem... But most of the posts on here say 99% of stalling problems are fuel related. If it was fuel related would it even run for 45 mins? Where should I go from here? Any suggestions?
Thanks! Ryan
Also, It doesn't seem like I am burning much oil(if any) I've used about 5-7 gallons of gas an the oil level hasn't seemed to move. Wouldnt the motor get extremely hot with no lube, because it doesn't.
Thanks! Ryan
