Yes and no...I didnt replace it, because it wasn't secured properly on that rear bolt, but now its fine. Still didn't start though as mentioned...
Where do i go from here?
edit: Got all six bolts including the bigger one that mounts to the eninge, still won't pop off, does the oil pump one hold it on??? The top part prys off but the bottom seems stuck on
There's 3 bolts at the bottom of the cover that you are not going to be able to remove unless you raise the motor. Remove the two bolts that hold the front motor mount to the hull. Use a nylon strap under the mount and lift the motor with a come a long. Place a block of wood under the motor. Remove the come a long. Remove the three bottom bolts on the mag. cover. You can leave the oil pump alone.
